| Application | GeoStudio |
| Version | Latest version |
| Primary Analysis | SLOPE/W |
| Keywords | GeoStudio, SLOPE/W, Bearing capacity, Footing, Pad foundation |
SLOPE/W can be used to analyze the bearing capacity of a shallow footing. The model must be defined in a particular manner in order to obtain results that are commensurate with analytical solutions. The classical bearing capacity analyses are completed in this example for the undrained and frictional cases.
