| Application | GeoStudio |
| Version | Latest version |
| Primary Analysis | SLOPE/W |
| Keywords | GeoStudio, SLOPE/W, Surcharge Loads, Slice Forces, Free-body Diagram |
Surcharge loads can be used in a stability analysis to model a variety of loads at the ground surface, including equipment loads and material placement. This simple example illustrates the application of a surcharge load and discusses how it is incorporated in the stability calculations.
