Examples - SIGMA/W - Overview
This section contains the GeoStudio SIGMA/W Examples
Bangkok Wick Drain Study
Berlin Tie-back Wall
Braced Deep Excavation in Soft Ground
Buried Pipe Stresses
Consolidation with wick drain
Construction of a Road Embankment
Cubzac les Ponts Embankments
Embankment on Geosynthetic
Excavation Below Water Table
Footing Load on Mohr-Coulomb Soil
Heave due to Infiltration
High Earth Pressure Coefficient K0
Parameterizing the Hardening Soil Model
Parameterizing the Modified Cam Clay Model
Parameterizing the SANICLAY Model
Parameterizing the Soft Soil Model
Progressive Failure in London Clay
Rapid Drawdown with Consolidation
Sequential Tailings Placement
Settlement due to Pumping
SIGMA/W Tutorial
Stabilization with Piles using SRS
Strength Reduction Stability
Strip Footing
Submerged Construction of an Excavation
Tie-Back Wall
Triaxial tests on Hyperbolic soil
Triaxial tests on Modified Cam Clay soil
Triaxial tests on Mohr-Coulomb soil
Triaxial tests on NorSand soil
Triaxial tests on SANICLAY soil
Underground Tunnel Excavation
Verification - 1D Consolidation
Verification - Bars in a Truss
Verification - Beams and Bars in a Frame
Verification - PWP Response of an Unsaturated 1D Column
Verification - Strength Reduction Stability
Verification - Hoek-Brown
Verification - Kirsch
Verification - Salencon
See also
Examples - SLOPE/W - Overview    [Examples]
Examples - QUAKE/W - Overview    [Examples]
Examples - SEEP/W - Overview    [Examples]
