| Application | GeoStudio |
| Version | Latest version |
| Primary Analysis | SIGMA/W |
| Keywords | GeoStudio, SIGMA/W, finite element analysis, stress, settlement, displacement, deformed mesh |
This is a fairly simple introductory example and the primary purpose is to demonstrate to new SIGMA/W users how to get started, to introduce the typical data required to do a SIGMA/W analysis, and to illustrate what can be done with SIGMA/W.
This problem focuses on computing stress changes in the ground beneath a cylindrical, fluid-filled tank.
