Please see our Component Downloads page for instructions on using the examples below and to explore additional component downloads.
This page provides download links for Quick Section templates.
These templates are for the Quick Section itself and are used to generate the overall section layout, such as the page borders, legend, title block, and strip area. Individual Strip templates used to represent each Location are stored and configured separately - some examples are listed below.
These templates rely on Strip Profiles. If you haven't used them before, you'll need to create a Strip Profile first.
We recommend opening the Quick Section template in Template Studio and selecting a default Strip Profile within the Strip Area object. Alternatively, a Strip Profile can be selected when generating the Quick Section.
| Item | Description | Example |
Imperial Ledger-Size |
Designed for Imperial units (feet) using some of the methods described here. Uses Ledger/Tabloid (11"x17") paper size. | |
Metric A3-size |
Designed for metric units. Uses A3 paper size. | |
Metric Ledger-Size |
Designed for metric units. Uses Ledger/Tabloid (11"x17") paper size. |
These Strip templates are used to generate the "stick log" or "fence post" that represents each Location on the Quick Section.
Additional examples can be found within our standard config packs.
CPT-Rf-qt-us-SBT-Imperial |
CPT Strip plotting Rf, qt, and u2, along with color-coding based on SBT. Uses Imperial units. Note: For config pack versions prior to 03.01, you may need to add a StaticConePenetrationData.SoilBehaviorType header to your data model - or - remove the reference to StaticConePenetrationData.SoilBehaviorType that is used for the Bar Chart color theme. |
CPT-Rf-qt-us-SBT-Metric |
