Accessing Component Examples from Standard Configuration Packs
Our standard configuration packs are regularly updated with new components that may not appear individually on the Component Downloads page. These packs can serve as a useful source of additional examples.
How to Access Component Examples
  1. Download the desired standard configuration pack as a .hbp file.
  2. Import the .hbp file to temporarily load the configuration into your cloud .
How to Extract Components
If you want to use a component from the pack in your own configuration:
Once you’ve extracted the components you need, you can safely delete the imported configuration pack from your cloud.
Component Compatibility
Note that components from newer configuration packs may not be completely compatible with older versions of configuration packs.
Please see the Troubleshooting and Modifying Component Examples topic here or contact our Support Team for additional assistance.
