AutoPIPE 2025 (25.00.00.299) - Read Me File
Product(s): AutoPIPE
Version(s): ALL
Area: Readme
Date Logged
& Current Version
July. 2025
25.00.00.299
What is New & Changed in AutoPIPE®
AutoPIPE 2025 is a yearly release which gets updated by occasional minor releases for security, critical fixes, and improvements. The details of the releases and timelines are provided below:
AutoPIPE® Requirements
More detailed installation information can be found in the AutoPIPE Quick Start Guide.
Product Version
Product AutoPIPE
Version 25.00.00.299
Language
  • English
  • Japanese
  • Polish
  • Chinese (Simplified)
Included Applications Versions
PCF Translator 1.5.0.299
PDS Translator 6.0.0.28
ADL Pipe Translator 1.0.0.35
ME101 Translator 1.0.0.20
iTwin Analytical Synchronizer 23.01.13.028
Bentley DGN Preview Handler 10.17.02.013
Bentley DGN Thumbnail Provider 10.17.20.11
Structural Property Catalog Server 10.00.07.003
iTwin Service Add in V2 25.00.02.01
Connection Client 25.00.00.15
Microsoft SQL Server Compact 3.5 SP2 x64 ENU 3.5.8080.0
Installation Requirements
Access to the Internet required for product installation. The minimum system configuration for installation:
Operating System
Microsoft Windows 10 x64 Professional or higher
Microsoft Windows 11 x64 Professional or higher
.NET Framework
4.8.1
When installing the product through the installer program, the required components will be installed automatically. The contents of the Desktop Prerequisite Pack include:
NOTE: AutoPIPE uses the following fonts on dialogs and in reports. These fonts are pre-installed with Microsoft Windows. If any of these font are missing, the text on dialogs and in reports may appear smaller/larger than usual. To install missing fonts, please repair or reinstall Microsoft Windows.
Minimum Profile
The minimum recommended workstation profile for running AutoPIPE is:
Memory 8 GB recommended.
Hard Disk 4 GB free disk space (not including Restore Point space requirements).
Video Graphics Card Any industry-standard video card which supports OpenGL 3D graphics.
ProjectWise
ProjectWise Server 10.00.03.299 with ProjectWise Explorer 10.00.03.453,
ProjectWise Server 8.11.11 with ProjectWise Explorer 8.11.11.
Note: ProjectWise Server and ProjectWise Explorer are only required if Bentley's ProjectWise is used to manage project documents.
OpenPlant Isometrics Manager
2024 (SES) - 24.00.02.13
Note: Users can use OpenPlant Isometrics Manager (OPIM) to review Stress Isometrics created by AutoPIPE without an entitlement for OPIM, provided it is opened from within AutoPIPE. Direct use of OPIM without an entitlement will log usage and may lead to charges. Click here for more information.
Word processing,
spread sheets, and access database
Microsoft® Office 64-bit.
Download, Installation, and Licensing
Refer to Knowledgebase article here for information on downloading, installing, and licensing AutoPIPE.
To complete the licensing process, you must have the appropriate roles assigned by your Site Administrator. If you have not been assigned these roles, you will need to contact your Site Administrator.
If you are experiencing problems logging into your Bentley account, please contact Bentley's Licensing department at 1-800-BENTLEY (1-800-236-8539). Outside the United States +1 610-458-5000.
Network Considerations - Network drives are only supported for data files. AutoPIPE software must be installed on a local client workstation. AutoPIPE data files must have full read/write access to be opened and edited.
Documentation
Program Help: Detailed feature information may be accessed directly from within AutoPIPE by selecting the Help command, or by pressing the Help button from any of the application dialogs. Be sure to explore the program Help for answers to your questions. A set of supplemental How To, Tutorial, and Reference Information documents in PDF format are provided in the Supplemental Documentation folder (Bentley AutoPIPE > Supplemental Documentation) of the main Program Help file (autopipe.chm).
Tutorials: AutoPIPE's help menu includes tutorials in Adobe.pdf format. Information and how to download a FREE copy of the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.
Piping Codes
This sections contains the list of piping codes, code editions supported and AutoPIPE license edition (Standard, Advanced or Nuclear) for which these items are supported.
Standard Edition Piping Codes
Piping Code Description
B31.1 Power Power Piping
B31.3 Process Piping Process Piping
B31.4 Liquid Trans. Liquid Transportation Systems for Hydrocarbons, Liquid Petroleum Gas, Anhydrous Ammonia and Alcohols
B31.8 Gas Trans. & Dist. Gas Transmission and Distribution Piping Systems
EN 13480 European Piping Code for Metallic Industrial Piping
General General Piping Code
ASME B31J
Stress intensification factors, flexibility factors, and sustained stress factors used in B31 piping analysis
Extra Codes Available in AutoPIPE Advanced Edition
AutoPIPE Advanced includes all codes available in AutoPIPE Standard, as well as the following codes.
CSA-Z662 Canadian Standards Association, Oil and Gas Pipeline System
CSA-Z662 Offshore Canadian Standards Association, Offshore Steel Pipelines
BS 806 Design and Construction of Ferrous Piping Installations for and in Connection with Land Boilers
BS 7159 Design and Construction of Glass Reinforced Plastics (GRP) Piping Systems for Individual Plants or Sites
SPC-2 Swedish Piping Code, Method 2
TBK5-6 General Rules for Piping, The Norwegian Pressure Vessel Committee
STOOMWEZEN Dutch Piping Rule D1101 of the Rules for Pressure Vessels
DNV Offshore Det Norske Veritas, Rules for Submarine Pipelines
MITI 501 3-1980
MITI 501 Class III Piping Code
KHK KHK E 012 Piping Code, Seismic Level 1 or 2 (Seismic Level 2 requires a KHK 2 Add-On license)
RCC-M French Piping Code for Power Industry
SNCT French Piping Code for Process Industry
SNIP Russian 2.05.06-85 Oil & Gas Russian SNIP piping code for oil and gas
ISO 14692 Petroleum and Natural Gas Industries - Glass Reinforced Plastics (GRP) Piping
B31.4 Offshore Offshore Liquid Piping Systems
B31.8 Offshore Offshore Gas Transmission
B31.12 Hydrogen Industrial Piping ASME B31.12 Hydrogen Pipelines (Section IP)
B31.12 Hydrogen Pipelines ASME B31.12 Hydrogen Pipelines (Section PL)
ASME NM-2 ASME Fiber-Reinforced Thermosetting-Resin Piping Systems
Extra Codes Available in AutoPIPE Nuclear Edition
AutoPIPE Nuclear includes all codes available in AutoPIPE Standard and AutoPIPE Advanced, as well as the following codes.
ASME NB Nuclear Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NB, Class 1 Components
ASME NC Nuclear Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NC, Class 2 Components
ASME ND Nuclear Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection ND, Class 3 Components
ASME NCD Nuclear Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NCD, Class 2 and Class 3 Components
JSME PPC Nuclear JSME S NC1: Rules on Design and Construction for Nuclear Power Plants, Class 2 Piping
Error History
The following outline identifies all major errors fixed in AutoPIPE 2025 (25.0.0) yearly release and occasional minor updates:
Copyright
TRADEMARK NOTICE
Bentley, the "B" logo, AutoPIPE, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
COPYRIGHT NOTICE
© 2025, Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "EULA.pdf" is included in the product installation folder.
Corporate Headquarters
685 Stockton Drive
Exton, PA 19341, United States
1-800-BENTLEY (1 800 236 8539)
+1 610 458 5000
Bentley EMEA
Bentley Systems International Limited
Charlemont Exchange
5th Floor, Charlemont Street
Dublin 2, D02VN88, Ireland
1800 948 368
+353 1 436 4600
Bentley Asia
Bentley Systems (Beijing) Co., Ltd.
Unit 1402-06, Tower 1
China Central Place
Beijing 100025, China
400 842 7516
+86 10 5929 7000
Online Information
requires access to the Internet
AutoPIPE Yearly Release Notes
How do I download, install, and license AutoPIPE?
Bentley AutoPIPE landing Page
