Design and Construction Enhancements FAQ's
On July 28, 2025, the Infrastructure Cloud launched enhancements to design and construction workflows to help engineering and construction teams work better together across project phases and meet the growing demands and complexities of infrastructure project delivery.
With these enhancements, all “Design” projects are now listed as “Project” under “Type of Project.” Below is a list of frequently asked questions regarding the changes:
Q:  Why is Bentley changing the project type from Design to Project?
A:   In an effort to provide a cohesive experience throughout the project lifecycle, we are implementing a singular project which will provide workflows to take the user through both design and construction phases of a project in preparation for eventual handoff to the owner operator.
Q:  Will this affect any of my data in my current projects?
A:  Any existing data in your Design projects will not be affected by the change. This change is just adding additional functionality relating to construction workflows formally only available through SYNCHRO Control.
Q:  Will I still be able to create new projects using my organization template projects?
A:  Yes, all of your existing Design templates will be available when creating or reprovisioning projects.
Q:  Are there any additional entitlements need to access the new Build functionality?
A:  No, your existing Bentley Infrastructure Cloud Connect and Bentley Infrastructure Cloud ProjectWise entitlements are still valid to benefit from the new functionality. However, access to the Administration section of the interface and the ability to configure some of the new functionality is still controlled by the entitlement a user is assigned.
Q:  Will my SYNCHRO Control projects be converted to the new 'Project' type?
A:  Not initially, but a process will be available at a later date to convert SYNCHRO Control projects to the new 'Project' type.
Q:  If I have a SYNCHRO license, will I have access to this project type?
A:  Yes. All SYNCHRO entitlements will allow you to access this project type.
Q:  What added functionality does the 'Project' type offer to current users?
A:  The new 'Project' enables some new functionalities that were previously available only in SYNCHRO Control projects including:
