| Application | GeoStudio |
| Version | Latest version |
| Primary Analysis | SLOPE/W |
| Keywords | GeoStudio, SLOPE/W, reinforcement, piles |
Piles are a common stabilization method for geotechnical systems as they can withstand considerable shear. SLOPE/W stability analyses simulate pile reinforcement by including a resisting force in the limit equilibrium formulation representing the shear capacity of a pile row.
This example compares the stability of a riverbank under natural conditions and when the riverbank is reinforced with piles.
