| Application | GeoStudio |
| Version | Latest version |
| Primary Analysis | SLOPE/W |
| Keywords | GeoStudio, SLOPE/W, search, technique, Fully-Specified |
In certain situations, the location of the failure or potential failure surface is known a priori. This would be the case, for example, when back-analyzing a failing slope or analyzing failure along a joint-set in a rock mass. In these cases, it is useful to take advantage of the Fully-Specified slip surface feature in SLOPE/W.
