| Application | GeoStudio |
| Version | Latest version |
| Primary Analysis | SLOPE/W |
| Keywords | GeoStudio, SLOPE/W, search, technique, Entry-Exit |
Historically the trial slips surfaces in a slope stability analysis have been specified by defining a grid of circle centres together with a range of circle radii. This approach has some undesirable side effects, and consequently, an alternative has been developed and implemented in SLOPE/W. It is called the Entry-Exit method. This illustrative example explains how the method functions and highlights the advantages.
