| Application | GeoStudio |
| Version | Latest version |
| Primary Analysis | SLOPE/W |
| Keywords | GeoStudio, SLOPE/W, search, technique, Block Specified |
The block specified search technique linearizes the slip surface into three sections. The search technique is best suited for critical modes of failure involving structural controls or, more generally, low strength layers that are spatially continuous and oriented at particular angle from the horizontal.
