| Application | PLAXIS 2D |
| Version | 2024.3 and later |
| Date created | 27 June 2025 |
| Date modified | 7 October 2026 |
| Original author | Wai Liong Lai - Technical Support Group |
| Keywords | PLAXIS 2D, Python, Output, Export, Plots, Failure, |
When performing a finite element calculation, PLAXIS will attempt to solve a series of non-linear equations to find a solution that is in equilibrium. In some cases, this final equilibrium might not be reached – in other words, the calculation did not converge, and PLAXIS will display an error code. These error codes would give a general indication of what went wrong or what to do, and they can be found in the Reference Manual. Certain error codes (most commonly Error 101 and 103) suggest reviewing the calculation results in Output to diagnose the issue.
For a better understanding of why equilibrium has not been reached, the following PLAXIS Output results should be inspected:
While these results can be manually reviewed through the program’s interactive graphical user interface, a more efficient and scalable approach is to use a Python script that automates the extraction of result sets. This script can save the results as images in a designated, easily accessible folder – streamlining the process and reducing manual effort.
The Python script is structured into several functional parts:
from plxscripting.easy import * localhostport = 10001 s_o, g_o = new_server('localhost', localhostport, password='YOUR_PASSWORD') import os import tkinter as tk from tkinter import simpledialog ROOT = tk.Tk() ROOT.withdraw() # Ask for the construction phase def ask_phase_name(): while True: phasename = simpledialog.askstring(title="Export Failure Inspection Plots", prompt="Type the construction phase number (e.g. Phase_1 or 1):") phasenr = None try: if phasename == str(int(phasename)): phasenr = phasename except: phasenr = None for phase in g_o.Phases[:]: if phase.Name.value.lower() == phasename.lower(): return phase if phasenr is not None: if phase.Name.value.lower() == "Phase_{}".format(phasenr).lower(): return phase # list of results to print resultslist = [g_o.ResultTypes.Soil.DeformedMesh, g_o.ResultTypes.Soil.Utot, g_o.ResultTypes.Soil.dUtot, g_o.ResultTypes.Soil.TotalDeviatoricStrain, g_o.ResultTypes.Soil.IncrementalDeviatoricStrain, g_o.ResultTypes.Soil.PlasticPoint, g_o.ResultTypes.Soil.PExcess] # Retrieve the project name project_path_dirname = os.path.dirname(str(g_o.GeneralInfo.Filename)) # Specify the folder name folder_name = "Failure_Plots" # Create the folder os.makedirs(os.path.join(project_path_dirname, folder_name), exist_ok=True) # Print a success message print(f"Folder '{folder_name}' created in '{project_path_dirname}'") # Create a folder in the same directory as the project to save the plots folder_location = os.path.join(project_path_dirname, folder_name) # Main phase = ask_phase_name() g_o.Plots[-1].Phase = phase for i in range(len(resultslist)): g_o.Plots[-1].ResultType = resultslist[i] export_path = os.path.join(folder_location, f"{phase.Name.value}_{resultslist[i]}_results.png") g_o.Plots[-1].export(export_path, 1920, 1080)
As mentioned previously, it is possible to include more result types to be extracted into the list. The full list of the result commands can be found in the ‘Output objects reference’ (in the program, go to the Help tab > Command Reference).
It is also possible to include other visualisation commands into the Python script to improve the legibility of the extracted results, like adjusting the legend of the plots, showing and hiding different elements, zooming, or changing the viewpoints (PLAXIS 3D only). These commands can be individually included in the script to suit each project, as explained in Export and format plots from PLAXIS Output using Python.
The use of this script is not limited only to troubleshooting calculation errors – it can also be used to streamline the extraction of results across multiple calculations, making it an ideal solution for projects with large datasets or repetitive tasks.
