| Application | GeoStudio |
| Version | Latest version |
| Primary Analysis | SLOPE/W |
| Keywords | GeoStudio, SLOPE/W, piezometric line, water, pore pressure, phreatic |
Pore-water pressures impose one of the greatest controls on the stability of slopes. The porewater pressure can be defined in a SLOPE/W analysis using a variety of approaches including a piezometric line, spatial pressure head function, or a finite element analysis. This example illustrates how to set-up and interpret the results of a SLOPE/W analysis that uses pore-water pressures defined using a piezometric line. Some of subtle nuances of the method are discussed.
