The following hardware requirements are suggested minimums. Systems with increased capacity provide enhanced performance.
| Processor | Intel® Pentium or AMD® processor 3.0 GHz or greater. |
| Memory | 1 GB minimum, 2 GB recommended. More memory almost always improves performance, particularly when working with larger models. 4 GB or more can help speed up solutions for very large complex models with large numbers of load cases. |
| Video | Graphics card supported by OpenGL. See the graphics card manufacturer for latest information on graphics drivers. 256 MB of video RAM or higher is recommended. If insufficient video RAM or no graphics card supported by OpenGL can be found, the application will attempt to use software emulation. For optimal performance, graphics display color depth should be set to 24-bit or higher. When using a color depth setting of 16-bit, some inconsistencies will be noted. |
| Screen Resolution | A minimum screen resolution of 1280x1024 is required, but higher is recommended.
Note: 4k displays are currently not supported.
| Hard Disk | Requirements will vary depending on the modules you are installing. A typical minimum is 500MB free space. |
| Supported Operating Systems |
*Not certified for version 25.00.01. For more information on Microsoft's application retirement policy, refer to the Microsoft Lifecycle Policy. For similar information on Bentley products, refer to the Bentley Lifecycle Policy. |
Additional RAM, disk space, and video memory will enhance the performance of STAAD Foundation Advanced.
The minimum amount of physical + virtual memory required by the program is over 600MB. You may need to ensure that adequate amounts of virtual memory are available and that parameters such as paging file sizes should be large enough or span over multiple drives if the free space on any one drive runs low.
You should have a basic familiarity with Microsoft® Windows® systems in order to use the software.
