How to set single click on 'Sing – Shot' setting
Introduction
Preferences Dialog, Look and Feel Category consists of controls that are used to set preferences for the appearance and location of user interface elements.
Controls how tools are selected with a single click of the Data button. Options are Locked and Single-shot. Default is Locked.
With Single Click set to:
  • Single-shot — you can select a tool for single-shot operation with a single click, or you can double-click it to select and lock the tool
  • Locked — you can select and lock a tool with a single click, or you can double-click it to set it for single-shot operation
Instructions
For using Single - Shot option, it is necessary activate Toolbox.
Open a project and activate ToolBox option
After selected Single-shot, you can select a tool in the toolbox for single-shot operation with a single click, or you can double-click it to select and lock the tool.
Please note that it is not possible use the Single-shot option with the tools in the Ribbon.
Other Languages Sources
