Applies To |
Product(s): |
OpenPlant Modeler CE |
Version(s): |
U11.2 & above |
Environment: |
Windows 11 (64 bit) |
Area: |
General
Subarea: |
Configuration Variable |
Original Author: |
Chanchal Mashalkar, Bentley Global Technical Support Group |
In OpenPlant Modeler, user encounter the clip view or volume discontinues to display graphics outside the defined handles, the issue may be related to specific configuration variables. Follow the steps below to resolve it:
Steps to Resolve
1. Navigate to the folder containing the Modeler.cfg file.
Path: C:\ProgramData\Bentley\OpenPlant CONNECT Edition\Configuration\Workspaces\<Your Workspace Name>\WorkSets\<Your WorkSet Name>\Standards\OpenPlant\Modeler\
2. Open Modeler.cfg using a text editor such as Notepad++ or Visual Studio Code.
3. Scroll to the section titled "Including View Functionalities".
4. Comment out all variables in this section by adding a # at the beginning of each line.
· This includes variables from MS_DRAWINGMODELSEED to MS_DGNLIBLIST_DRAWINGSEEDS
5. Save the changes to the file.
6. Restart OpenPlant Modeler to apply the updated configuration.
· Note: For more details, refer to the official Bentley documentation or help resources.
Still a Problem?
If above problem persists, then please log a Case and contact the Bentley Global Technical Support group. While logging a case, please include all relevant information to get in-depth analysis for a solution or workaround.
https://bentleysystems.service-now.com/kb?id=kb_article_view&sysparm_article=KB0111221
Comments or Corrections?
Bentley's Global Technical Support group requests that you please confine any comments you have on this Knowledge Base Article entry to Forum section. THANK YOU!
