GeoMedic - Collect Diagnostic Information
Table of Contents
Download GeoMedic
Since we make periodic updates to the GeoMedic program, we always recommend that you download the latest version from the following link:
Before You Start
What is GeoMedic?
Running GeoMedic
To generate a GeoMedic diagnostic report:
  1. If you have GeoStudio USB dongle licenses, attach these to your computer before running GeoMedic.
  2. Run the GeoMedic executable that you downloaded from the link above.
  3. Follow the instructions in GeoMedic.
  4. Save the output file when prompted.
  5. Attach the GeoMedic diagnostic report to your support case or support email.
Example - GeoMedic Running
