| Application | PLAXIS LE |
| Version | PLAXIS LE CONNECT Edition V21 Update 8 |
| Date created | 13 June 2025 |
| Date modified | 13 June 2025 |
| Keywords | PLAXIS, Limit Equilibrium, LE, export, database, SVSoils, material |
This video explains the two ways of exporting your soil database from SoilVision Soils when using PLAXIS LE.
The first option explains how to achieve this per material, and the second option gives the step-by-step process for your entire database.
