Product: RAM Structural System
First Affected Version: 2025 (25.00.00)
Fixed in Version: 25.00.01
Area: Frame Analysis
Issue #: 1687335
Checking the option to generate the additional load cases for Orthogonal Effects based on ASCE 7 Seismic loading causes the program to crash.
It affects various editions of the ASCE 7 code. Models with existing seismic loads including orthogonal effects are unaffected.
It should generate additional load cases representing the 100% +/- 30% vectors.
Using custom load combinations is an option to generate the equivalent effect of these combination vectors.
To be fixed for version 25.00.01.
