Q. Common solutions to issues found in the comparison log file following the execution of an ATS
Solution #1:
Restart the system and try executing ATS again
Solution #2:
Confirm Virus protection does not hinder ATS functionality
Contact company IT department and confirm that you have permissions for full Read / Write capabilities to the following locations:
      1. AutoPIPE's ATS installation folder (Default: C:\Bentley\AutoPIPE XXXX QAR ATS).
      2. AutoPIPE's program folder (Default: C:\Program Files\Bentley\AutoPIPE XXX
      3. User Profile Path (Default: C:\Users\USERNAME\AppData\Roaming\Bentley\AutoPIPE XXXX\)
      4. Program Data Path (Default: C:\ProgramData\Bentley\AutoPIPE XXXX\)
Solution #3:
Confirm No ATS folder are set with Read Only Properties
 Contact company IT department and confirm that all folders under AutoPIPE's ATS installation folder have Read Only folder properties enabled.
Solution #4:
Run ATS Manually
      1. Reboot the computer
      2. Log into Connection Client
      3. Start AutoPIPE
      4. Open following model from ATS folder location, C:\Bentley\AutoPIPE 2024 QAR ATS\Test Systems\Models\QA23\QA23.dat
      5. Press Analyze All (Analysis > Analyze > Analyze All)
      6. Generate Quick Reports for Results using Output Report (Result > Quick Reports > Output Report)
      7.  In a moment the report should be displayed.
      8.  Open Window's File Explorer, and navigate to the model folder location, C:\Bentley\AutoPIPE 2024 QAR ATS\Test Systems\Models\QA23\
      9. Folder should now contain the following files
      10. IS QA23.OUT file in the folder location:
        • If Yes - Great, you should now be able to run the ATS, open QA23 folder, delete all files except *.DAT and *.CMB. Stop here, and run the ATS as designed.
        • If No -  There is a problem continue below.
      11.  Notes:
        • If rights/privileges problem on the folder then model wont open
        • If model opened and executed successfully but OUT file not shown in ATS model folder under Test systems, then AutoPIPE failed copying back the OUT file for TEMP
Solution #5:
Run ATS with interface and Messages ON
      1. Try executing ATS with show interface to see if AutoPIPE was actually launched with required licenses.
Solution #6:
Run ATS Repair
      1.  Run the ATS installer application, select Next
      2. Follow on screen prompts to repair the installation.
      3. Try to run the ATS with User Interface and Messages turned OFF. Was the ATS able to complete without issue?
        • If Yes, Great - complete ATS installation as needed.
        • If No, continue below.
Solution #7:
Nuke and Reinstall to a different folder
      1. Using typical Windows commands, complete uninstall the ATS application, and delete the folder: C:\Bentley\AutoPIPE XXXX QAR ATS
      2. If the user has a different folder location on the local computer with full Read / Write permissions, reinstall the ATS to this folder
        (ex. C:\Myfolder\AutoPIPE XXXX QAR ATS\)
      3.  After installation, try to run the ATS with User Interface and Messages turned OFF. Was the ATS able to complete without issue?
        • If No, contact Bentley.
