W2261-64: B31 App J: The following tees have a ratio of crotch thickness... message appears
Problem:
The following is displayed when using AutoPIPE
 * * * W A R N I N G - MODEL * * *
W2261-64: B31 App J: The following tees have a ratio of crotch thickness to run thickness
less than 1.1. Set the tee type of these tee(s) to 'Other'
Why and how to avoid it?
This warning refers to a specific clause in ASME B31.J code related to tees. Find type of component in table 1-1 (Flexibility and Stress Intensification Factors), and refer to the various notes that apply. The notes provide details on this ratio.
Avoidance:
Update the model such that the ration is within the requirements of ASME B31J.
"Warnings" Messages
