The following is displayed when using AutoPIPE
* * * W A R N I N G - MODEL * * *
W2261-81: B31 App J: The reducer ratio r2/D2 should be greater than XXXX.
The program will continue to use the provided geometry.
Why and How to avoid it?
This warning refers to a specific clause in ASME B31.J code related to reducers. The flexibility and stress intensification factors apply only if the all the noted conditions are satisfied (refer to table note).
Avoidance:
Update the reducer characteristics so all of the noted conditions are meet.
Notes:
