05. Additional details regarding the PCF Translator's "Attribute Mapping" tab in AutoPIPE
When importing a PCF file there are additional settings that can be used to successfully convert a PCF file into an NTL file that can then be opened by AutoPIPE. These additional settings can be found on different tabs on PCF translator dialog. This particular KB is dedicated to issues related to "Attribute Mapping" tab.
  1.  Example 1 - PCF with attributes defined
  2.
