Important Announcement: Retirement of Hevacomp
Why is Bentley Systems retiring Hevacomp?
As previously communicated, Bentley Systems is retiring the following Hevacomp products: Hevacomp Dynamic Simulator, Hevacomp Electrical Contractor, Hevacomp Electrical and Mechanical Designer, Hevacomp Mechanical Contractor, Hevacomp Mechanical Designer, Hevacomp Mechanical System Builder, Hevacomp Electrical System Builder, and Hevacomp Legacy.
This decision follows a thorough evaluation and reflects our continued commitment to delivering forward-looking, innovative solutions that align with the evolving needs of our users. All intended Hevacomp capabilities have now been fully integrated into OpenBuildings Designer, offering a more streamlined and powerful solution for Building Design and Analysis.
Users can continue utilizing familiar Hevacomp workflows within OpenBuildings Designer, while benefiting from its enhanced design tools and functionality.
When will Hevacomp be retired?
The Hevacomp products mentioned above have reached the discontinued or end-of-support phase and are no longer available for download through Software Downloads.
For more details, please refer to the Bentley Lifecycle Policy on our website.
How long will Hevacomp be supported? 
We will continue to provide Hevacomp support until January 1, 2026.  Bentley will offer limited technical support, including assistance in evaluating queries and, where possible, provide workarounds.
Please note that no further development, updates, or patches will be issued.
What will happen during the Expiring Support phase (through December 31, 2025)?
Existing users may continue to use Hevacomp products with limited technical support.
What happens after the Discontinued Support phase begins (starting January 1, 2026)?
Technical support will no longer be available, and Hevacomp product entitlements will no longer be included with an OpenBuildings license.
What should I expect as an existing user? 
If I have an active SELECT subscription:  
You will no longer be charged SELECT pricing after January 1, 2026. You may retain your discontinued licenses; however, they will become node-locked licenses.
Is there any alternative option to node-locked licenses under SELECT:
 No, there are no alternative options. All discontinued licenses will become node-locked.
If I do not have an active SELECT subscription:
Your licenses will already be node-locked and will not change.
If I am using Hevacomp under an E365 subscription:
E365 users may continue using Hevacomp if needed; usage will be considered part of OpenBuildings Designer. If you require the installer, please contact the support team.
When do these changes take effect?
The licensing and subscription changes will take effect on January 1, 2026.
Who is affected by these changes?
All existing Hevacomp users with an active annual SELECT subscription, Virtuoso subscription, or E365 plan.
Will the products stop working?
No, Hevacomp will continue to function once the license is converted to a node-locked type.
Can I purchase more Hevacomp licenses after January 1, 2026? 
No, new Hevacomp licenses will not be available for purchase after January 1, 2026.
What is the recommended Bentley alternative to Hevacomp?
We recommend transitioning to OpenBuildings Designer. With Hevacomp’s intended capabilities now seamlessly integrated into OpenBuildings Designer, upgrading ensures you have access to a more efficient and powerful building design and analysis solution.
Explore the application here: OpenBuildings Designer
What are the benefits of upgrading to the OpenBuildings Designer?
You can continue using familiar Hevacomp workflows within OpenBuildings Designer while gaining access to enhanced design tools, modernized interfaces, and advanced analysis capabilities.
Will Bentley provide assistance with the transition to OpenBuildings Designer?
Yes. Bentley has created a comprehensive migration guide to support a smooth transition. Our team is also available to assist and guide you throughout each step of the process.
What steps should I take to ensure a smooth transition?
We recommend contacting your Bentley Account Manager or Success Manager for personalized assistance. Additionally, we encourage utilizing our coaching blueprint for a seamless migration.
Who can I contact if I have further questions or concerns? 
For additional support, reach out to your Bentley Account Manager, Success Manager, or visit the Bentley Support Portal to connect with our dedicated support team.
