We are mindful that for a very long time Hevacomp has been central to the work of many Design Engineers - more so now than ever, as dependence on such design tools has increased to take advantage of the efficiencies and capabilities on offer.
So we can certainly understand that any change to something that became core to the working day of many, may seem a daunting prospect at first.
This article is intended to offer clarity on what exactly the move to OpenBuildings Designer entails, and to help provide resources for Hevacomp users so they can successfully migrate to the new software.
We are mindful that design engineers want a quick and concise method to run their calculations. Under pressure for results, they don't want to have to draw an entire BIM model to get their CIBSE Gain or Heat Loss reports.
It is true that OpenBuildings Designer is BIM software with a very wide range of capabilities. However, alongside this, OpenBuildings Energy Simulator is included as standard.
OpenBuildings Energy Simulator is independent software dedicated solely to energy modelling and building performance, based entirely on the capabilities of Hevacomp Design Database and Simulator.
It is easy to use, and modelling a building takes a matter of minutes. The familiar workflows from Hevacomp are at the core of this, now streamlined into a more intuitive, modern, user-friendly interface.
You can trace your rooms in 2D via floor plans, and import projects via Hevacomp, GBXML or OpenBuildings Designers ASM.
All capabilities such as the Load Calculations, Dynamic Simulations, Part L, and Radiance Daylight Simulation are included as standard as part of your license.
Within OpenBuildings Designer there are different workflows for each design discipline, such as Structural and Architectural. The Netsys capabilities can be found within the Mechanical discipline.
We are pleased to announce that with the release of OpenBuildings Designer 2024.2 (v24.00.02.45) , all piping and duct sizing capabilities are now available.
All the familiar Hevacomp workflows are now present, where you can easily trace single-line schematics, or import a floor plan to trace your routing in 2D, just like in Netsys.
In addition, OpenBuildings now opens up multiple new modelling options to choose from to best suit your needs, e.g.:
All OpenBuildings training courses have been made freely available to users:
These training resources should cover all the major topics you need, with additional guidance on our Energy Simulation Wiki .
Our Part L Energy Assessor course has been made freely available on our LearnServer, and can be accessed by clicking here.
Registration for the related Energy Assessor examination is very straightforward as all exams are now online. Exams are announced on our Forum - see here for example.
We are aware that becoming familiar with new software can take time for some, and many will have ongoing Hevacomp projects. With this in mind, throughout this transition Technical Support has remained available to help with any Hevacomp issues.
This will remain the case until Jan 1st 2026, when Hevacomp will become unsupported.
For further details regarding this timeline, along with licensing details and FAQ, please find guidance in this announcement.
If there is anything you need help with, be it guidance on how best to migrate to OpenBuildings, technical support, training, or any other guidance, we are here to help.
