| Version | PLAXIS 2D all versions PLAXIS 3D all versions |
| Date created | 25 April 2025 |
| Date modified | 25 April 2025 |
In both PLAXIS 2D and PLAXIS 3D Output software, you can create curve plots for any pre- or post-selected curve points. This video demonstrates how to plot curves for multiple phases, which use different colours in order to assist with visually recognising the transitions.
