This Civil Validation and Analysis tool allows for interactive Rail Equipment Sighting Validation from a train drivers perspective based on specific train characteristics against a federated iModel. The analysis is performed against static trackside equipment against a moving driver's eye camera.
{Figure: Civil Design Validation and Analysis - Train Signal Sighting }
In the Civil Frontstage, open the left widget panel and select the Civil Design Validation and Analysis tab.
{Figure: Civil Design Validation and Analysis tab within Bentley Infrastructure Cloud}
The Summary page presents any existing analysis runs for review. To create a new Analysis, select from the dropdown the desired tool.
{Figure: Add New Civil Design Validation}
Adding new will open an associated form allowing entry of required inputs -Run Name, Alignment Selection, Train Characteristics and Sighting Requirements, that all need to be completed prior to analysis.
{Figure: Signal Sighting Setup}
The name entered will be visible in the ‘Summary page’
Selection of the Alignment can either be from the graphics or from the drop down list of available Alignments
Predefined starting values are provided that will need adjusting based on the train characteristics for
Provides the run specific list of equipment to be analyzed. An empty template file is provided that creates analysis per row based on the parameters defined in the Sighting Locations file.
Sighting Class – the tool supports 3 primary sighting assessments that are specified in the Sighting Locations file for
Or All can be run in a single analysis.
[Note: a given setup can be duplicated from the add new summary page and edited to adjust values provided to give a comparison between two runs at say different speeds or to check for different train equipment.]
Provides the user defined point list with classifications and sighting requirements for each point being assessed Please note the formatting outlined in the template file
The results are presented in tabulated view indicating the status for each point Analysis based on the sighting requirements.
{Figure: Analysis Results}
The results table presents each object id summary indicating success / failure status and also provides a way of navigating the table and model since it synchronizes the model view to fit the selected objects run results. For the selected object id in the table the sight line will be colour coded for any deficiencies, the details for these deficiencies can be reviewed in the Object Visibility Results table detail by expanding the run results
{Figure: Expanded Object Visibility Results
To aid understanding of analysis the sight line and any failure can be zoomed to in its own window and the slider used to travel along the sight line for an understanding of any failure.
Figure: Object Visibility Results - Zoom to point
Figure: Object Visibility Results – View Options
Enter Drive Mode – Sets the main view into ‘drive mode’ along the current Object id’s sight line.
Figure: Object Visibility Results – Drive Mode
[Note: To aid understanding of analysis the sight line and any failure can be zoomed to in its own window and the slider used to travel along the sight line for an understanding of any failure.]
