</colgroup
| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Startup |
| Date Logged & Current Version |
April 2025 24.00.02.243 |
While using WinDBG application, AutoPIPE was opened,
The following error occurred:
*** ERROR: Symbol file could not be found. Defaulted to export symbols for C:\Windows\SYSTEM32\vm3dgl64.dll
This issue is directly related to installing AutoPIPE on a Citrix server inside of a virtual machine (VM). Adter running a WinDBG and revewing the log file it was apparent that the error was linked to a specific DLL - vm3dgl64.dll
Performing a google search for this DLL found a reference here that resolved the issue.
VMware Tools 12.5
Llvmpipe which is used for OpenGL application is not unloading properly.
This is a known issue and currently there is no resolution.
To workaround this issue set a system environment variable SVGA_ALLOW_LLVMPIPE=0
Below are the steps to set the variable.
Environment Variables...' button at bottom right.Variable Value' box in the 'Edit System Variable' window and click OK to save the value back to Path variable.Environment Variables...' window.The Path environment variable is now set.
- In few scenario, The application will crash even after adding the environment variable " SVGA_ALLOW_LLVMPIPE=0" on Windows VM.
- For those situation, ,Make sure to update the device display adaptor version to 9.17.9.4.
AutoPIPE Crashes / Freezes on Start-up
