Product: | MicroStation |
Version: | CONNECT, 2023, 2024 |
Environment: | N\A |
Area: | General MicroStation |
Subarea: | General |
When opening a files in MicroStation they are Read Only and cannot be edited.
There maybe multiple reasons for files being Read Only when opened in MicroStation, check the following.
To check this open Windows Explorer at the location of the files(s). right click on the file and Select Properties.
In the Properties dialog select the ‘Security’ Tab
Select your Group or Name and check your Permissions and that ‘Allow’ is ticked against appropriate options
If Permission is set to ‘Deny’ select ‘Edit’ to change. (You may need your IT administrators assistance to check/change your permissions
Or use the CMD commands ‘attrib’ and ‘icacls’ to check the settings for the file(s) and Parent directories
Please seek assistance from your CAD administrator if changes to Custom Configuration is required.
If requiring further assistance please raise a Case with support
MicroStation - Open File Read-Only Permanently Active
