| Version | PLAXIS 2D 2024.2 and later PLAXIS 3D 2024.2 and later |
| Date created | 07 April 2025 |
| Date modified | 07 April 2025 |
| Original author | Stefanos Papavasileiou -
Technical Support Group
| Keywords | PLAXIS, SoilTest, soil, test, lab test, virtual lab, Python, API, py, cookbook |
The SoilTest facility offers a quick and convenient method to simulate basic soil lab tests on the basis of a single-point algorithm, i.e., without the need to create a complete finite element model.
Typically in order to perform a numerical analysis you need to properly calibrate the parameters from the laboratory test and the SoilTest tool. For this, you would typically need the secant and tangent values of certain graphs to ensure a good match and be confident on the numerical analysis simulating a similar response to the real soil speciments.
This Python script provides a solution to running SoilTest with a provided material using the Triaxial test. You can specify the result types to allow for a calculation of a secant and tangent value for the provided results and determine if further calibration is required.
If a calibration is required, then you can adjust a material parameter and run the same workflow to re-evaluate the results.
This script has been tested with PLAXIS 2D and 3D 2024.2 using Python 3.12.3.
soiltest_triaxial_example_interactive_tan_sec_results py [Python compressed file]
