Why Limpet and Half Pipe Coil is not considered as light reinforcement in EN 13445?
Question
Answer
Larger the vessel diameter is lower the theorical elastic pressure of a stiffener on a cylinder is :
As the following criteria is not met, the coil is not considered as light stiffener :
Avoidance :
  1.  Provide additional light stiffening or heavy stiffening
  2.  Increase Shell Thickness
Bentley AutoPIPE Vessel
Support Solutions and FAQ's
Error Messages
Warning Messages
