Question
| Version(s): | ALL |
| Area: | |
| Date Logged & Current Version | April 2025 45.00.03.001 |
Problem:
The following is displayed when I run the application:
Errors:
991 NOZZLE N10 : Not checked, only one central opening may be taken into account on bolted cover following EN13445 Annex G.
How to resolve?
User has checked an option Optimization Use EN 13445 Annex G/EN 1591 and has an offset nozzle mounted on the flat cover.
As per EN 13445 Annex G clause G5, Blank flanges may have central opening and hence offset nozzle is not taken into account in the calculation.
