The SACS development team is pleased to announce the release of SACS 2024 (24.00.05).
SACS 2024 (24.00.05) Release Highlights
Joint Can Fix
Fixed an issue with Eurocode 3 (2005) design code check that could cause Joint Can to crash.
List of Fixed Defects
Joint Can
- 1617931 - Fixed an issue with Eurocode 3 (2005) design code check that could cause Joint Can to crash.
