| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Modeling |
| Date Logged & Current Version |
March 2025 24.00.02.243 |
Following message appears when performing a design check in AutoPIPE:
W2182-28: Flanged valve/flexible joint should have mating flange/flanged component at Point A02
Why and how to avoid it?
This is only a warning message to the user to confirm that this is modeled correctly.
Is the AutoPIPE Model correct:
Example:
If yes, then the warning message can be ignored.
If no, then update the model accordingly.
