Widget size: 1 x 1, 1 x 2, 2 x 1, 2 x 2, 3 x 1
The message board is a widget that displays messages stored via the "Message Board Admin" screen found in the Menu>Administration section. See separate help section for a detailed explanation of the Message Board Admin page.
In the admin section, messages can be added to a site, an individual dashboard or across the whole organization. Messages can be up to 2500 characters in length. Those dashboards that have the widget included will be displayed, ready for new messages to be added.
When added to the dashboard, the messages are viewed by levels of importance and can be scrolled by clicking on the up or down arrows or set to scroll automatically.
Value | Default | Comment |
Widget Heading | Message Board | Enter the name of the widget as it is to appear in the heading. |
Show Priority at Level | 10 | Option of Never or 1 (least important) through to 10 (most important). Set the level of priority to start the display of messages. |
Order By | DATE | Set the order of messages by date or importance. |
Show Org Messages | No | Option of Yes or No. Display all messages that are global to the whole organisation. |
Show Site Messages | No | Option of Yes or No. Display all messages that are global to all Sites. |
Refresh Period | No widget refresh | Select a refresh period from the drop down menu from between 15 seconds to 1 hour, or no refresh at all |
There are no properties required for this widget.
