Widget size: 2 x 1, 2 x 2, 4 x1, 4 x 2
The Logbook widget can be used as a place to record events (in the form of text logs) that have or will have an impact on your system in some way.
It can be used to record items on an action plan that can be removed from the list once implemented.
Logbook entries can be initially stored against a site selected from the treeview but can also be stored against individual containers/points or multiple points if configured in the widget configuration.
The information in each column of the logbook can be sorted alphabetically by clicking on the column header.
To add a new logbook entry, press the green "+" icon to display the pop-up, window which allows you to add an entry against the selected site or stored container/point.
Logbook entries against the container/point are added by entering the date, author, summary, and details. Entries against points are shown when one or more point ID is entered into the "POINT1" cell of the Properties configuration. Entries against containers are shown when a container ID is entered into the "Container ID" of the configuration. All entries in the logbook will then be against the configured container or point(s).
Entries may appear on Overlay charts or Engineering charts, when configured.
Clicking on a log entry will open a new pop-up to display the details of the entry. These can also be edited and saved if the user has editing rights.
When new logbook entries are created, the user will default to the currently logged in user.
Setting the widget configuration (Widget Specific = Yes), restricts the Logbook widget to contain only entries specific to the widget itself and to ignore any other entries within the organisation, region, point, etc.
Pressing the information icon will show the current logbook setting.
Click the delete (red cross) button beside an entry to open a confirmation pop-up. Click OK to remove the entry from the widget.
The format of the logbook widget is very flexible in terms of columns displayed, and the choice can be daunting. However, when a new widget is created, the default settings will display only the following columns: Date, Author, Summary, Details, and Action.
| Value | Default | Comment |
| Widget Heading | Logbook | Enter the name of the widget as it is to appear in the heading. |
| Show Date Column | Yes | Show or Hide Column |
| Show Author Column | Yes | Show or Hide Column |
| Show Summary Column | Yes | Show or Hide Column |
| Show Details Column | Yes | Show or Hide Column |
| ContainerID | Site | Enter the container ID to store the entries against. |
| Column x Heading (x4) | Edit respective Column Heading | |
| Refresh Period | No widget refresh | Select a refresh period from the drop-down, between 15 seconds to 1 hour, or no refresh at all |
| Widget Specific | No |
| Show Full Path | No |
| Show Date Created | No |
| Show Date Modified | No |
| Tree Level A | Blank |
| Tree Level B | Blank |
| Tree Level C | Blank |
| Level A Heading | Tree Level A | Provides a heading for the column filled with the name of the container selected in the 'Tree Level A' column above, if it is enabled. |
| Level B Heading | Tree Level B | Provides a heading for the column filled with the name of the container selected in the 'Tree Level B' column above, if it is enabled. |
| Level C Heading | Tree Level C | Provides a heading for the column filled with the name of the container selected in the 'Tree Level C' column above, if it is enabled. |
| Function | Blank |
| Function Heading | Blank | A header label for the column that displays the results of the function specified above, if any. |
| Show Note Parent | No |
| Note Parent Heading | Point | A header label for the column that shows the Note Parent item name, if it is enabled. The default is Point as entries are most commonly attached to points. |
| Period Selection | disabled | Dashboard/Report Selector is the available option. |
Drag and drop the required point to link the logs to from the tree. Enter a point ID here to store entries against a specific point.
