Widget size: 1 x 1
The Alarm Summary widget presents alarms generated today and the number of alarms that have, and have not, been acknowledged.
Note: For details of the Alarm Level link, View All, and Historic Alarms tables, please see
Alarm Management.
- Alarm levels are color-coded from urgent Red to tranquil gray.
- The number of current alarms that fall into each category appears next to the bell graphic.
- Click the Alarm Level link (High Fault, High Alarm, High Alert, etc.) to view a table of current alarms of that category.
- Click the View All button to open a Current Alarms table presenting details of all active alarms.
- Click the Historic Alarms button to open a table presenting details of all recorded alarms.
Quick Config Options
Click the Quick Config icon to change the Widget Heading, to Show/Hide All Org Alarms, and to designate the Refresh Period.
- If Show All Org Alarms is set to Yes, then the widget will ignore any site identifier and show alarms for the whole organisation. If this option is set to No, then as you click through the dashboard navigation tree, only the alarms under the selected site are displayed.
- Click the Advanced Configuration link to view Asset data in addition to the editable interface elements.
