This page enables perspectives (configured via "Perspective Management") to be applied to containers within the treeview.
Clicking on a container in the treeview will display its current attributes.
To assign a perspective, click on the site/container.
Click on the "Apply Perspective" button. This will add the set up perspectives that are listed.
Once assigned, values need to be entered for each one by double clicking on the Value cell of each perspective. The Value is the name to display for the container in that selected perspective.
Once entered, click the "Save Changes" button to store.
To remove a perspective, select a row and click the "Remove Selected Row" button.
