Data Workpack Generation
Data workpack grids are templates that can be designed in the system to allow you to download a template to Excel, add data, and upload data back into the system from Excel for multiple points/attributes across multiple assets/locations. Data can also be entered into the grid, directly on the page.
A data workpack grid is comprised of one or more assets (containers) displayed in a list on the screen with one or more points and attributes added as further columns. Each point/attribute mapped in the Column Configuration can have data uploaded via Excel or directly into the grid and save values for multiple points/attributes for multiple locations into Amulet.
Note: Data entry via a data workpack is more beneficial when the structure is presented in a uniform or templated way.
Each point/attribute column will be mapped to an asset/location in the grid, and the user will be notified when a point/attribute does not exist for any asset/location added.
Note: To access the Digital Twin Explorer feature for any asset on the grid, click the value in the first column, which will serve as a link to the DTE.
