Operation to create new templates is exactly the same.
The templates folder in the sources tree reflects the templates available in the templates database.
In this example, the templates database has two folders containing templates. The ‘Chemical Templates’ folder has been expanded here.
Example task:
Ensure warning button is off. Click if necessary.
Drag and drop a container from Palette to ‘C3 Org’
When the warning appears, click OK.
Select ‘3’ in Number To Create.
Drag ‘CCW’ from templates and drop on new container. Warning appears.
Click OK.
Three instances of the template are created.
