Operation for importing structure from XML files is exactly the same.
Select the required file in the sources tree and drag/drop to the desired container and ensure the ‘Number To Create’ is set back to 1 (or the number required).
A warning appears.
New structure is created beneath ‘New Container’ according to the contents of the XML file.
