Palette
The following is explanation by example:
Task: Add a new container under ‘Demo’.
Drag the container from sources and drop on ‘C3 Org’.
A warning appears.
Click ‘OK’.
A new container is added.
Note that the warning popup will appear each time an item is dropped on the 4D Analytics tree. This warning can be temporarily disabled by selecting ‘Yes’ in the drop-down next to ‘Suppress Warning’.
Task: Suppress warning popup and add 3 new process parameters to ‘New Container’.
Select ‘Yes’ in the drop-down next to ‘Suppress Warning’.
In ‘Number To Create’ drop-down, select 3.
Drag Process Point from sources and drop on new container.
This time, no warning appears.
Note that when new items are created, they appear in the Renaming table on the right. A description of how to use this area follows later in this document.
