Tree Manager
Tree Manager adds new functionality that streamlines the creation of new structure in the asset hierarchy. The Tree Manager is of a popup window containing a tree of structure sources where required items can be selected/dragged, and a copy of the 4D Analytics data tree where the selected items can be dropped.
At the time of writing, the sources are grouped into 3 categories
The interface also contains an area for easy renaming… more on this later.
