XY Charts
The new XY chart is similar to the existing Analytical Viewer; however, it differs in that it does not display data as a time series. The new chart accepts a selection of two independent points and matches data from both points using timetag and then displays an XY plot with the first point on the X-axis and the second on the Y-axis.
Accessing the XY Chart
The XY chart is accessed from the Digital Twin Explorer. A function button has been added to the selection tool.
The XY chart button is only available when two (and only two) points are selected.
XY Chart
When you select two points and launch the XY chart, the chart appears in pop-up window.
By default, the XY chart interrogates the data for both points and loads all of the data where timetags match.
Options Menu
Toolbar Functions
The exported file shows the full paths and names of the two points, each of the data rows, and the corresponding, common timetag.
The XY Chart also supports Episodes if they have been configured in Episode Administration.
Episodes are displayed by selecting from the drop-down on the top menu bar.
The chart will then update to show only the data for the period of the selected episode.
