Use the Analytical Viewer to add, display, and modify logbook entries.
Click the Show/Hide Options icon and check the Show Logbooks box.
The cursor is now equipped to identify a point on the chart, so left-click on the desired point.
- Points with Logbook entries are indicated by a book symbol.
To edit a Logbook entry, click the book icon. When the Logbook dialog opens, change the Date, Summary, or Details for the selected logbook entry.
When you have completed either reviewing or creating a logbook entry, click the Save button to record any changes made to the dialog or click the exit icon to close the dialog without recording changes.
Note: The permission for adding new logbook entries is controlled by the Group Action Logbook Add/Edit. Without this permission, you can still view any existing logbook entries.
