Point Configuration
The point configuration tool allows the user to view and configure settings on the point.
Add points to the selection tool and open the configuration tool by clicking on the configuration tool icon.
The Configuration Tool window will open. There are four tabs – Point Description, Latest Values, Plot History, and Calculated Parameters.
Point Description
Latest Values
Plot History
This tab is only applicable to calculated parameters.
