When you are Configuring a Calculated Point, use the Configure Units, Quantities, and Formulas dialog to help choose the calculation required by the point.
Units | Physical Quantity | Description |
Mpy | Velocity | mils per year |
Mmpy | Velocity | millimetres per year |
Mils | Length | thousandth of an inch |
Mm | Length | millimetre |
Litres | Volume | litres |
V | Electrical Voltage | voltage, power / current |
°C | Temperature | degrees centigrade |
°F | Temperature | degrees Fahrenheit |
m/s | Velocity | metres per second |
pH | pH | potential of hydrogen |
Ppm | Concentration | parts per million |
Ppb | Concentration | parts-per-billion, 10−9 |
gm/barrel | Concentration | grams per barrel |
Gms | Mass | grams |
Bar | Pressure | |
ft/s | Velocity | feet per second |
Psi | Pressure | pounds per square inch |
Amps | Electrical Current | amperes |
mA | Electrical Current | milli-amperes |
USGPM | Volumetric Flow Rate | US gallons per minute |
Gallons | Volume | gallons |
IBCs | Volume | intermediate bulk containers |
Drums | Volume | drums |
