It is possible to apply up to 3 property filters on the report table widget using the Filter1, Filter2, and Filter3 configuration parameters. Each filter is made up of 4 parameters separated by commas – Type,Name,Operator,Value. These parameters are detailed below:
So to filter the report on a project manager ‘Joe Bloggs’, the following may be keyed into the Filter1 configuration setting – Property,PROJECT_MANAGER,EQ,Joe+Bloggs. Note that the space has been replaced with a + sign to ensure the URL remains valid. Other reserved characters such as ampersand (&) and equals (=) will also need to be encoded using the percent-encoding method (e.g., ‘&’ is ‘%26’ and ‘=’ is ‘%3D’).
