MicroStation brings a seamless integration in interoperability with Esri solutions by importing and exporting in the Esri File Geodatabase format!
The MicroStation product team is proud to announce the new Esri File Geodatabase Import and Export functionality, available in MicroStation 2024 (24.00.02.62).
With this new feature, you can seamlessly integrate your GIS data into the CAD environment for analysis, simulation, and visualization. This will enable you to make informed decisions that are better aligned with real-world conditions. The ability to import and export in the Esri File Geodatabase format ensures interoperability with Esri solutions, making it easier to work with your GIS data.
The Export functionality allows you to populate your GIS with design data, update your GIS content, or share it with stakeholders who require this file format. This new capability will enhance the way you work with GIS data and improve your overall productivity.
For more details, please refer to the Import and Export documentation sections.
We are searching for MicroStation users of all levels who would like to test the early concepts of upcoming features!
